how to make find command show size of files also
Brittany Snow
Member level 3
I am learning Linux on evaluation board, there is a question, how can I make find command to show size of files also? Do I need to use -exec ls -l or xargs etc?
vinodstanur
Advanced Member level 3
Kerala (INDIA)
for every command there will be a help option....
try
find --help
and read the usage
there you can see all options related to the find command
srizbf
Advanced Member level 5
you have to use the -exec ls option.
but to apply to the found file only.
for example if you want to find *.txt
give
find . -name "*.txt" -exec ls -l {} \;
the . operator should be changed to your reqd directory.
Brittany Snow
Member level 3
try
find --help
and read the usage
Help is too large for me to read.
---------- Post added at 14:39 ---------- Previous post was at 14:37 ----------
give
Sorry but I can't find the size of the files. Do you have other command about it? Thanks.
bjuric
Serbia
The size is displayed in bytes. Use -h switch in ls to show human readable format. Like ls -lh
find . -name "*.txt" -exec ls -lh {} \;
About -exec and xargs... look at it this way...
-exec will perform given command on every found object separately
xargs gets all results as one big chunk (like a txt file, only from RAM)
Brittany Snow
Member level 3
Try: "find --help | less" (or use Shift+PgUp/PgDn to page back & forth through text in a terminal). Other options:
man find
info find
Yes , thank you very much.
---------- Post added at 15:13 ---------- Previous post was at 15:12 ----------
This is the quick fix and it help very much. Thanks very much
