how to make exact delay in c18 compiler
engineer khan
Member level 3
Member level 3
Hello every body!
please help me in producing exact time delay in c18 compiler, 1msec or 1sec
hello,
if you don't use interrupt , you can count number of elementary MCU Cycles.
1 cycle duration= 4/ (Fosc in MHz) in µsec
// if Fosc=16MHz
void Tempo_1mS()
asm{
          MOVLW 210 ;
          MOVWF _N1;   // 8 bit counter
 ici:
             nop ;   //1
        nop ;
        nop ;
        nop ;
        nop ;
        nop ;
        nop ;
        nop ;
        nop ;
        nop ; //10
        nop ;
        nop ;
        nop ;
        nop ;
        nop ;
        nop ; //16
        decfsz _N1 ,F ;   //decr counter, skip over next instruction if equal to zero
        bra ici   ;
        nop;
        nop;
        nop;
        nop;  // add 4x0.25=1µS to round tempo pile poil to 500µS
if you want to use Interrupt timer
initial value depend of your FOSC (or Quartz) .. prescaler value ...timer 8 bit or 16 bits ..
ans if you don't have an exact timer value ,you can add some "NOP" asm code to
get an accurate time .. (depend also of accuacy of Quartz (<20ppm ?)
any example :
// PIC18F serie : il faut timer0 sur 16 bits
// delais pour FOSC=16Mhz
void Delay_uS(unsigned int x);
void Delay_mS(unsigned int cnt);
void Delay_1S(void);
{unsigned int y;
 y=x;
while(--y != 0);
  #ifdef DEBUG
  return;
  #else
  INTCONbits.TMR0IE=0;     // no interrupt
  T0CON=0b00000001;  // Timer OFF, 16bits, internal, prescaler=1:4
  TMR0H=0xFC; //hi(64537);      // 1.0mS avec 1:4
  TMR0L=0x19; //lo (65537);
  while(cnt>0)
  T0CONbits.TMR0ON=1;
  while(INTCONbits.TMR0IF == 0); // wait over
  INTCONbits.T0IF=0;
  cnt--;
  T0CON=0;
  #endif
void Delay_1S(void)
  T0CON=0b00000111;  // Timer OFF, 16bits, internal, prescaler=1:256
  TMR0H=0xC2; //hi(49911);      // 1.0 S avec 1:256
  TMR0L=0xF7; //lo (49911);
  T0CONbits.TMR0ON=1;
  INTCONbits.T0IF=0;
  T0CON=0;
have a look on This
even it is not C18 !
