i am planning to build a sine wave inverter. the sine wave is not a smooth sine wave. to make the sine wave the voltage is first 30 volts, then 60 volts then 90 volts, then 120 volts, then 90 volts, then 60 volts, then 30 volts, then - 30 volts, then - 60 volts, then - 90 volts, then - 120, then -90 volts, then -60 volts, then -30 volts, then this pattern repeats. if i feed this pattern to my laptop recharger, my laptop recharger will recharge my laptop and won't get damaged? the specifications on my laptop recharger say 100 to 220 volts.
