Hi
You can do it with 2 555 ICs
First one you configure as 5 sec single shot.
Second one with 1Hz astable multivirator.
Out put of first 555 will be active low you connect it to
reset pin of second 555 IC. Since reset is active low
you need to add a transistor invertor as shown in attched
block diagram
Hope this helps
