how to make 8 bit in verilog
vead
Full Member level 5
Full Member level 5
india
hello embers
I want to make port for microcontroller in verilog code
I want to write verilog code for 8 bit port
module port (data_in,data_out )
input[7:0] data_in;
output[7:0]data_out;
wire [7:0]data_out;
endmodule
I think its not enough tell me what I do to make port in verilog I did google but I did not get success
hi,
what is the relation between output and input?
you just define the relation in the code ,that is enough
As I haven't run across any microcontrollers with a separate input and output data interface bus (parallel peripheral interfaces are usually bi-directional) I've taken the liberty of showing you a bi-directional interface.
At a minimum, with only 1 register in the FPGA would be something like:
Code Verilog - [expand]
8
module port (
  inout   [7:0]   data_io,
  input           r__w_n,
  input           enb_n,
  input           clk
// rest of code...
endmodule
with multiple registers that need to be accessed you'll also need an address bus:
8
9
module port (
  input   [15:0]  addr,
  input           r__w_n,
  input           enb_n,
  input           clk
// rest of code...
endmodule
Note the different syntax for Verilog 2001 port declarations. You should really switch, it's been 13 years since it was introduced and it seems universities (like those in India) seem to be stuck in the HDL stone age.
Regards
