I have a quesiton and request related to loading and running files in Matlab.
I have 500 data files generated in FDTD.
I would like to load all these datas in Matlab and run a program,
already written in Matlab, for each of these 500 datas. How can I do it
to avoid time-consuming process?
How Big is each file...?
I mean the size of each file... If the run time data obtained from the file is large
then memory will be overrun if you try to process them parallely...
What I want is just to load all these 500 dat. files
in Matlab and run the already written program in Matlab.
Programm will do the same process
for each file. The output will be 500 new dat. files.
What is the best way to do this process in Matlab?
I'm not sure if there is any way to process data parallely in matlab. Even if you do so it would take the same amount of time it took to do the process one by one.
You could only increase the computational efficiency of your code to decrease the computation time...
