I tried following code with modelsim version 5.5d on linux x86 platform.
It works perfectly OK! You can try this one on ur end.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity counter is
port (
clk : in std_logic;
reset_n : in std_logic;
count : buffer std_logic_vector(7 downto 0));
end counter;
architecture behave of counter is
begin -- behave
counting: process (clk, reset_n)
begin -- process counting
if reset_n = '0' then -- asynchronous reset (active low)
count <= (others => '0');
elsif clk'event and clk = '1' then -- rising clock edge
count <= count + 1;
end if;
end process counting;
end behave;
I ran following commands on command promt to compile simulate and generate vcd
file.
vlib work
vcom counter.vhd
vsim -c counter
force -freeze -repeat 10 clk 0 0, 1 5
force -freeze reset_n 0 0, 1 33
vcd file test.vcd
vcd add -r *
run 1000 ns
quit
Hi, nand_gates,
I tried the counter design, but I still couldn't see other bits of the counter than counter(0). The VCD viewer I use is downloaded from **broken link removed**
When using vcd2wlf provided by Modelsim to change the generated vcd to wlf and view it by modelsim, there is no problem with the count signal -- all bits can be displayed.
Sounds like a bug/issue with WaveVCD tool - why not try GTKWave or just use Modelsim's waveform viewer?
Aji
fiw0000 said:
Hi, nand_gates,
I tried the counter design, but I still couldn't see other bits of the counter than counter(0). The VCD viewer I use is downloaded from h**p://www.iss-us.com/wavevcd/
This seems to be a bug in wave vcd viewer. While dumping modelsim
dumps individual bits of std_logic_vector into vcd dumpfile; which info
wave vcd viewer is not able to understand. You better go for gtkwaves.
