hi i am currently doing project on microcontrollers for that i have layout in positive form .i want to invert this as i need negative to give in my college
can you help me how to do this in eagle
pls reply fast as i have very little time
my email id is jaineshshah_88@yahoo.co.in
You may want to remove the shorts from your design before producing a PCB. Generally, many printer drivers have an option to print a negative graphics, also many simple graphic viewers can manipulate a bitmap file, e.g. irfanview.
In eagle when you click on print you will get an check box for mirror
select it and then you can directly print an inverted image of the layout ( if you have a printer installed )
or you can save that inverted image to a file......
Another option is select the whole layout using GROUP SELECT button
then use FLIP button to invert the whole pcb layout or schematic
