s3034585 said:
Hi
u can write a for loop to initialize ur ram as per ur requirement. say for eg... when there is a reset u initialize to to 0 the same ways u can initialize to you values after reset and then start using it.....
but for that u need to have all the values u want to initialize into the ram....
Actually..I have already done that but i had problems when i want to compile the code because my memory size s 4096 bytes i m creating a memory which my data are stored in 128 bits per address . The address using 8 bits(256 location) which gives me a memory which can store 4096 bytes... can u help me in other ways like .mif file or any other...
