I know in the Spectre, the model libraries can be installed in different categories, such as tm(typical mean condition), ws(worst speed), wp(worst power)...
Can I do this in Pspice?
In the Pspice, I have to add the file name and path for each library file in the simulation profile. There are tons of files in each category. If I add these files manually, it is really time consuming. And the model files call each other, so I 'd better to install them all.
There is a file named *_tt0.lib. The foundry told me that this file should contain the links to all the tm model files. But after I added this file, the correct index file can't be generated for it. So the simulation aborted all the time.
I need sb. help me with the Pspice. Thank you very much!
