how to add power pad in design .i already added I/O pad by adding pad in verilog-gate-level netlist generated from synthesis tool and back-end design on innovus(encounter) cadence cad tool.
in verilog netlist there is NO power supply pin .
How to add supply VDD, VSS pad in gate-level-verilog code so that power pad came in back-end design in innovus(encounter).
first step is to add the power/gnd cells to the netlist. you have to manually do that.
second step is to tell innovus about your global nets. read the documentation, it is fairly easy. then you connect the pins of the cells you added to the globalnets you created.
