cheat0821
Newbie level 5
For power isolation, I need to insert power-cut cell in my design.
I used "PDIODE8W" in my I/O library for different voltage levels isolation between digital and analog domain. There are two pins inside this power-cut cell, VSS1 and VSS2.
So, when I use the command "InsertPad", how should I write in tdf file to make sure that both VSS1 and VSS2 are connected correctly?
Please give the example or explain insert a power-cut cell in another way.
Thank you!
Thank you!
