how to increment an output pins!!!!
snoopcat
Junior Member level 1
please i'm beginner,i wanna generate deferent analog signal by using the dac08 and a PIC,how can i increment the output (PORTF for exemple)from 0x00 to 0xff using a loop of course
i wanna get something like that
f0 f1 f2 f3 f4 f5 f6 f7
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 1
0 0 0 0 0 0 1 1
0 0 0 0 0 1 0 1
look at
or google "pic course"
Hi!
it should be something like this
unsigned char data=0;
TRISF = 0XFF; //ALL PINS OUTPUTS
while(1)
PORTF=data++;
if(data==0xff)
data=0;
delay();
void delay(void)
unsigned int i;
while(++i!=1000);
I have assumed that u are programming in C.
It can also be done in assembly quite easily.
I have used the delay function to generate some delay after sending a particular value to the port. You can increase or decrease this delay depending upon the type of signal that u want to generate.
Regards.
Added after 4 minutes:
I made one mistake (a terrible one)
in the above code make this change
TRISF = 0X00;
Thanks.
i think as our buddy has demonstrated is the right way to do
thnaks a lot guys ans sorry for the desargement
