Dear Sir,I'm not sure you can, or should do that. The parts come from the library so you would have to edit all the individual component shapes to use more pixels. If you did that the schematic would look horrible!
Why do you want to do it?
Brian.
As you said, I went to Preferences/Schematic Editor Options/General Options and changed the Default bus width as 12 and saved the preferences changes. But it is not showing any increase in thickness of wires or components. It is showing as like earlier thin wire lines and components.if you go toreferences/Schematic Editor Options/General Options there is a box labelled "Default Line Width" which defaults to '6' but if you make the value larger it increases the connecting line and component outline widths.
As you said I did it, now it is working nicely. But little problem I am facing, at the Gate of the Transistor Vertical line is only appearing as "thinner". Remaining everything is O.K. How to make it thicker that also near the Gate of the Transistor, which is appearing as "Thinner".As a temporary fix, you can increase the LINE width (not 'bus' as you stated but I can see you tried it anyway) then use a screen capture program. The change does not occur until you click 'OK' in the Windows version, it is immediate in the Linux version.
