Plateau
Junior Member level 3
Dear friends, is everything ok?
I have a little electronic problem that I would like to share with you all.
Well...At home I have some lead acid car batteries that I really want to charge but I haven't any good charger to do it.
Looking for a solution, I've thought in using a DC-DC step up regulator with an array of PNP or NPN transistor as current driver. At the first moment, it seems good, but I really don't know if it will work.
A friend of mine gives me a DC-DC step up regulator based on XL6009 (similitar to LM2577) and it can provide a voltage output between 5 and 35 volts (considering the input voltage: 3 to 32v) with 3A of current.
The main problem is: Can I use a 12v 15A power supply as XL6009 voltage input and some transistors as current driver to get an output of 14v 8A?
Many thanks and regards,
Pedro Rosa.
Transistor approach
XL6009 Datasheet
Pedro Rosa.
Transistor approach
XL6009 Datasheet
