I am new in antenna design and I need help to increase the bandwidth of my printed meandered dipole antenna. the current bandwidth of this antenna is just only 13MHz and i wish to increase it to 500MHz. Can someone please give me some ideas on how to increase the bandwidth?
I am using FR4 substrate with Er 4.7.
What is your antenna central frequency?
Google for "wideband fr4 dipole" images, there are many papers with similar configuration.
For very wide bandwidth use another topology, for example magnetoelectric dipole.
According to antenna theory, there's an upper limit for the achievable bandwidth of an electrical small antenna. It's unlikely that you can increase the bandwidth of a meandered dipole without making it larger or add intentional losses.
There is not much to do to increase the BW of this antenna type (printed meandered dipole). Its BW is about 7% of central frequency (for 2:1 VSWR). Depending of the dielectric material and its thickness.
Changing the antenna size it will change only the resonant frequency, but not the % of the bandwidth.
