Don't put the display control routine within the main loop. Use a timer interruption activated flag to determine the timing. The better solution is the PWM output, but for this you should add a PNP transistor in series with all segments.
Here is the part of code used for multiplexing written in Bascom. As I said, everything works fine with bigger delay in Waitms(example 100 ms)I'm assuming you are putting delay commands in the isr vector and are controling display in the main program, but it is in fact just a guess and my assumption may be totally wrong. Unless you show your code, you'll not get a precise answer.
'$sim
$regfile = "REG51.DAT" ' specify the used micro
$crystal = 12000000 ' used crystal frequency
---variables----
Tran1 Alias P1.0
Tran2 Alias P1.1
Tran3 Alias P1.2
Disp Alias P2 '
Do
Bi = Vou1 / 100
Gosub Convert
Set Tran1
Disp = Bi
Waitms 5
Reset Tran1
Waitms 5
X = Vou1 / 10
Bi = X Mod 10
Gosub Convert
Set Tran2
Disp = Bi
Waitms 5
Reset Tran1
Waitms 5
Dim Y As Integer
Y = Vou1
Y = Y Mod 100
Bi = Y Mod 10
Gosub Convert
Set Tran3
Disp = Bi
Waitms 5
Reset Tran3
Waitms 5
Convert: 'convert data to seven segment format
Select Case Bi
Case 0 : Bi = &H3
Case 1 : Bi = &HCF
Case 2 : Bi = &H24
Case 3 : Bi = &H84
Case 4 : Bi = &HD8
Case 5 : Bi = &H90
Case 6 : Bi = &H10
Case 7 : Bi = &HC7
Case 8 : Bi = &H0
Case 9 : Bi = &H80
End Select
Return
Loop
End
Your code has no comments, which turns hard to understand without knowing the meaning of each variable.
'$sim
---variables----
Tran1 Alias P1.0 ' Tran1,Tran2,Tran3 -->NPN transistor used for switching the displays
Tran2 Alias P1.1
Tran3 Alias P1.2
Disp Alias P2 ' Segments of displays conncected to PORT2 '
Do
Bi = Vou1 / 100 ' display ones of Vou1
Gosub Convert
Set Tran1
Disp = Bi
Waitms 5 'delay of 5 miliseconds
Reset Tran1
Waitms 5
X = Vou1 / 10 ' display tens of Vou1
Bi = X Mod 10
Gosub Convert
Set Tran2
Disp = Bi
Waitms 5
Reset Tran1
Waitms 5
Dim Y As Integer ' display hundreds of Vou1
Y = Vou1
Y = Y Mod 100
Bi = Y Mod 10
Gosub Convert
Set Tran3
Disp = Bi
Waitms 5
Reset Tran3
Waitms 5
Select Case Bi
Case 0 : Bi = &H3 ' display zero
Case 1 : Bi = &HCF 'display one
Case 2 : Bi = &H24 'etc...
Case 3 : Bi = &H84
Case 4 : Bi = &HD8
Case 5 : Bi = &H90
Case 6 : Bi = &H10
Case 7 : Bi = &HC7
Case 8 : Bi = &H0
Case 9 : Bi = &H80
End Select
Return
Loop
End
14mA is fine....
I´m not sure...
With a 1:3 multiplex rate you should use 3 x 14mA..
(I assume your multiplex rate is 1:3 and the recommended DC current of each segment is 14mA)
The total high side drive current goes then up to 3(ratio) x 14mA x 7(segments) = about 300mA
Klaus
Your questions still lacks of more explanations, as for example the fact that you mentioned the impact of changing from 5ms to 100ms delay, but there are 3 lines where you call 'Waitms 5'. Should we assume your changed simultaneously all these lines ?
Another unmeaning things on your code:
Display units: Set Trans1 / Reset Trans1
Display dozens: Set Trans2 / Reset Trans1
Display houndreds: Set Trans3 / Reset Trans3
What is the logic behind that switching ?
* Don´t expect higher brightness with multiplexingThis leads to the questionnaire the whole idea of multiplexing.. Cause brightness (current of 14mA) is good for bigger delay of switching
"the whole idea of multiplexing"...
The idea of multiplexing is to share the available display time equally between the used digits (e.g. three in your design) and to minimize dead time with all digits off. Respectively you want moderate delays (short enough to avoid flickering, e.g. several milliseconds) during digit on-time and very short delays (e.g. some microseconds) during off-time.
Displays have specifications for average and peak current. With three digits, you can usually the increase the peak segment current by a factor of three without exceeding the permitted peak current, so that the average current and respectively the display brightness is roughly maintained compared to non-mux drive.
You need to reduce the 330 ohm resistors, possibly also base resistors, use "stronger" digit driver transistors (higher current gain at 500 to 800 mA).
Another possibility is increasing the contrast ratio by placing a piece of the ubiquitous "red plastic" in front of the LEDs and blocking all external ambient light from between the plastic and the LEDs.
That will create a very dark background, even in high ambient light, and make the lit segments appear much brighter.
