M1 w=?? l=?? m=?? model name as=?? ad=?? ps=?? pd=??
While producing hspice netlist using cadence, the MOS device's model name is not being included in the netlist.
I checked 'edit simulation information' in tools>cdf>edit and found that 'componentName' contains the model name information, but in the netlist it's not coming.
If u r using GPDK or PDK, then model names are automatically bind to your MOS symbol and you can see this model name in context menu (edit-> prop-> objects)
If you are using a general models, then you should manually add these to MOS symbols while placing it(generally) along with width and length. so that they will appear when you extract netlist
