Hello,
is there any way to reduce the phase noise of the atmel atrf212 chip such that we can transmit up to 14 dBm in the band 868-868.6 MHz with an RF front end CC1190. For example CC1101-CC1190 can meet modulation bandwidth requirements and transmitting up to 18 dBm, see page 17, figure 4.18 and page 19, number 7: CC1101 Register Settings: AN094 -- Using the CC1190 Front End with CC1101 under EN 300 220.
In particulary it says:
"Improving the CC1101 phase noise reduces the modulation bandwidth for a given output power and allows operation up to +18 dBm output power."--Z
It should be a way to to the same with Atmel ATRF212 transceiver.
Thank you very much
Yours faithfully
