How to improve LDO high frequency PSRR?
colinwang
Member level 3
ldo psrr
hi all,
How to improve the high frequency PSRR of LDO with a fixed output capacitor?
two conditions:
large output capacitor: uF
small output capacitor: nF or pF
Thank you all!
high psrr ldo
A description of acrchitecture that you are using, or a schematic and the results that you currently get would be useful
psrr ldo
The schematic and the psrr is shown as follows. The load capacitor is 10-100pF and the load current is up to 20mA.
how to improve psrr
This is the psrr plot. How can i improve the psrr at high frequency? If i want to get more than 40dB psrr at 1MHz, are there any good methods?
Thank you!
high psr ldo
If your loading is 100pF, is that still stable?
high frequency psrr
yes, the stb analysis shows that it has enough phase margin and gain margin.
psrr of ldo
What is the psrr nature of the bias current? If that is fine, the best charaterisitic possible is to delay the rolloff until the second pole...
ldo psrr
Could you explain more clearly? Are there any special structure can be added to improve the high frequency psrr?
thank you!
improve psrr
The PSRR curve can be broken into 3 regions:
Region 1 - 0 to 200Hz
Region 2 - 200Hz to 100KHz
Region 3 - above 100KHz
For high PSRR in Region 1, improve your Bandgap PSRR to be above 60dB at DC.
In this Region, the Open-loop gain of the Error Amplifier must be large of at least 70dB till a frequency of 10KHz.
For region 2, only the open-loop gain of the Amplifier comes into play
Region 3 is mainly dominated by the large output caps, bigger caps gives higher PSRR.
I have attached a good article on this here. Also the link to this article is at
focus.ti.com/lit/an/slyt202/slyt202.pdf
Regards,
svraj
psrr ldo improve
Thank you very much!
I also want to know how to achieve high psrr in high frequency for cap-less LDO. Without the large output capacitor, the high frequency psrr is really a difficult to achieve. Are there any suggestions?
