Jul 22, 2007 #1 C caosl Advanced Member level 4 Joined Mar 26, 2006 Messages 114 Helped 17 Reputation 34 Reaction score 4 Trophy points 1,298 Activity points 1,969 hi,all i want to import the simulated data from spectre to matlab for further process, but how to do this? I try the BYU website's method, (http://www.et.byu.edu/groups/ece451web/cadence-help/cadTOmat.html) but after simulation, it told me that the fprintf imcompatible with data...! any other good skills exist???
Jul 22, 2007 #2 E elbadry Full Member level 6 Joined May 6, 2005 Messages 347 Helped 72 Reputation 144 Reaction score 10 Trophy points 1,298 Location Egypt Activity points 3,884 There is the ocnPrint command. This allows you to print data into a text fiile.
Jul 23, 2007 #3 L littleckt Newbie level 1 Joined Jul 23, 2007 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,285 use table function from wavescan viewer. You can select some waveform and generate a table. Of course, ocean script is a more advanced function and you can almost do anything with it.
Jul 23, 2007 #4 C caosl Advanced Member level 4 Joined Mar 26, 2006 Messages 114 Helped 17 Reputation 34 Reaction score 4 Trophy points 1,298 Activity points 1,969 thanks for elbadry and littleckt's help, i will try the method you offered
