I would appreciate if anyone would tell me how to import the Pro-engineer 2001 object to HFSS 9.1. Which type of file need to be export in Pro-Engineer 2001 to HFSS 9.1?
I am not an expert on pro-e, but from my experience of import/export, SAT is the best format, can you export SAT from pro-e? HFSS v9.1 will take SAT v8. Failing this, try STEP, I would recommend avoiding IGES - too crude for EM simulators.
I tried to import the STEP format from ProE wildfire into HFSS v9.2 before. It seems there are some problems for the imported 3D modeling. I was told that HFSS v10 can heal the imported structure, but never try it before.
By the way, if the structure drawn in ProE is very complicated, it seems it will take hundreds of hours to simulate it. Maybe doing some simplification for the model before import is necessary.
