How to import information from HyperTerminal into a file
mariuszoll
Member level 5
Member level 5
I implemented a RS232 communication between my PIC18F4550 and PC, and now I want to import the information from HyperTerminal into a file, in order to create a logfile.
I'm writing you because, I don't know how to do it, and I am eager to know if you have ever made something similar.
Could you help me please?
Thank you in advance.
Marius
I don't know how to do it for hyper terminal. But there are other terminal evaluation softwares that do it.
See this link.
Try Tera Term
I had to do something similar but I also required the PC to send data to the PIC too. So I had built a GUI using Matlab to do everything.
Open Hyperterminal. Configure Baud and port. Go to Transfer->Capture Text-> select a file (with.txt extention) and click start. To check if data is logged Go to Capture Text-> stop. Open the file and see the logged data. Enjoy!
