edajason said:
You have to compile the load command, just read the instruction. As long as you can load the data in matlab window, you will be fine.
huangjw said:
hi fun.zhao,
how do i add the HspiceToolbox,
i follow the document,but it doesn't work.
thanks in advance.
Added after 5 minutes:
The file link is here,
h**p://www-mtl.mit.edu/researchgroups/perrottgroup/tools.html#hspice
Follow the instruction, compile the command loadsig; and then you can load the data:
x=loadsig('eye.tr0'); %Load the hspice output file eye.tr0 into matlab variable x
lssig(x) % List the variables in the x datastructure
y=evalsig(x,'v_3'); % Assign the hspice variable v_3 to matlab
Now you can plot whatever you want.
Hspice Toolbox for Matlab
written by Michael Perrott (h**p://www-mtl.mit.edu/~perrott)
while at Silicon Laboratories (h**p://www.silabs.com)
Copyright (C) 1999 by Silicon Laboratories, Inc.
This software is distributed under the terms of
the GNU Public License (see the COPYING file
for more details), and comes with no warranty or support
error in hs_allocate_sf: unexpected values in block1 header
??? One or more output arguments not assigned during call to 'loadsig'.
