you need the adder and differance amplifier
the heart of the adder is a inverting configuration amplifier.
the diff between the two is that for the adderboth inputs are at the inverting ( inverting amp) or non inverting (non inverting amp). So that the signal is beeing added.
in the second case one signal is connected to the inverting input of the opamp and the second non inverting in in this way the two signals will be subtraced since one has + sign other -.
see both circuits here: http://www.wam.umd.edu/~toh/ElectroSim/Adder.html
