Hi
I'm working on designing unequal power Wilkinson power divider. I need to implement a 295-ohm microstrip line. The problem is that it's not practical to implement.
I found two main techniques to increase microstrip/stripline impedance.
1- using offset double-sided parallel strip line
2- using defected ground microstrip line.
both of them are a bit difficult to implement.
Are there any other method can be used to increase microstrip/ stripline impedance to check it ?
Thanks
Ammar
