how to implement a function in C
BMWE
Hello
given the following code:
void func(){
char *var=NULL;
str_cpy(var,"text1");
str_cpy(var,var+2);
some print(var) // result: xt1
some_free(var)
i should implement the str_cpy function.
how would you implement it efficiently (without memory leaks)?
That you wrote there will end in an error for sure since you are not allocating "var" before use. If not, the "some_free(var)" will.
The correct way should be:
void func(){
char var[32];   // 32 is arbitrary and may be any number larger than the size of "text1" + 1.
str_cpy(var,var+2);
some_print(var) // result: xt1
strcpy: the simplest way you can do it is like the following **broken link removed** (replace __PSTRING with char*).
or you can add a third parameter and pass a maximum quantity of chars to copy.
void func(){
str_cpy(var,var+2);
but why to change the problem?
if i was able to change it, then i wouldn't apply for help
what? is a problem for school? why you can't change it?
I still believe it won't work because you are passing null, not even the pointer to a pointer.
So.........
#undef NULL
#define NULL   some_malloc(32)
// implement str_cpy as said before
// then the code you wrote at the beginning.
