How to implement 1 to 4 demultiplexer in VHDL
Rfboy
Member level 1
Hi guys,
I need to implement a simple 1 to 4 demultiplexer in vhdl...please help me ithis is the my first time in vhdl !!!!!
The input and output are a byte and the selector are a line with 2 bits...
Thak you
nand_gates
Advanced Member level 3
demultiplexer vhdl code
Its very simple...
library ieee;
use ieee.std_logic_1164.all;
entity demux is
  port (
    D0  : in  std_logic_vector(7 downto 0);
    D1  : in  std_logic_vector(7 downto 0);
    D2  : in  std_logic_vector(7 downto 0);
    D3  : in  std_logic_vector(7 downto 0);
    SEL : in  std_logic_vector(1 downto 0);
    Y   : out std_logic_vector(7 downto 0));
end demux;
architecture behave of demux is
begin  -- behave
with SEL select
  Y <= D0 when "00",
       D1 when "01",
       D2 when "10",
       D3 when "11",
       (others => 'X') when others;
end behave;
master.ro
Member level 1
Romania
demux in vhdl
Hello !
I think that the code posted by nand_gates is a mux not a demux.
A demux has 1 input and 4 outputs and the input is connected to the output selected by selection.
    V
hamadeh
Member level 5
Lebanon
8 bit 1: 4 demultiplexer vhdl code
Hi guys, we are posting replys to this thread although it was created 3 years ago :D
any way I think one way of creating a 1 to 4 8bit demux is as follows :
entity demux is
  port (
    D   : in  std_logic_vector(7 downto 0);
	 Y1  : out  std_logic_vector(7 downto 0);
    Y2  : out  std_logic_vector(7 downto 0);
    Y3  : out  std_logic_vector(7 downto 0);
    Y4  : out std_logic_vector(7 downto 0));
end demux;
begin
process(D,SEL)
begin
case SEL is
when "00" =>
	Y1 <= D;
	Y2 <=  (others => '0');
	Y3 <= (others => '0');
	Y4 <= (others => '0');
when "01" =>
	Y2 <= D;
	Y1 <= (others => '0');
when "10" =>
	Y3 <= D;
when "11" =>
	Y4 <= D;
when others => null;
end case;
end process;
end behave;
in this demux when an output is not selected it will provide a zero, if you need to preserve the last output just delete the Y# <= (others => '0'); , this of course will generate latches at the outputs.
