Slayerza
Full Member level 5
- Joined
- Oct 22, 2005
- Messages
- 295
- Helped
- 27
- Reputation
- 54
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- South Africa
- Activity points
- 3,462
18f4550 and USB
I have an embedded system using a PIC18LF4550 running at 20MHz and 3.3V. The question is how do I hook up the USB to the PIC? Electrically speaking I gathered from the USB spec that a LDO on the Vbus (+5V) line of the USB should do the trick.
Thus making the PIC side of things 3.3V.
I should also mention that the PIC side of things is self powered.
Is this correct?
Thanks in advance
Henri
Is this correct?
Thanks in advance
Henri
