nikhileshsawarkar
Newbie level 5
8052 timer 2
Hi again experts,
Some problem in handling my Timer2.
I'm using 8052 series AT89s8253 controller. I'm using Timer2 as 16 bit auto reload mode.My compiler is Keil uV2. I wanted to get interrupt every 1 ms so values I've set in RCAP2H = 0xFC and RCAP2L = 0x65.
the code is
//in main
timer2_init()
RCAP2H = 0xFC ;
RCAP2L = 0x65;
T2CON |= 0x00;
T2H = 0xFC ;
T2L = 0x65;
TR2 = 1;
//isr get called every 1ms
int counter = 0;//global int
timer2_isr () interrupt 5 using 1
counter++;
if(counter == 60000)//will go inside every 1 min.
counter = 0; //X ZONE
But Im getting something wrong...
1. Regardless of any value I put in RCAP2H and RCAP2L , Its going in 'X zone' every 12 seconds(approx) but not in every min (This I've observed in Debugger and CRO both)
2. It is exicuting isr every 0.1 ms(approx) insted of 1ms.
My Q is is there any other presetting required for it to be working correctly?
Thanks and regards,
Nikhilesh
Hi again experts,
the code is
//in main
timer2_init()
RCAP2H = 0xFC ;
RCAP2L = 0x65;
T2CON |= 0x00;
T2H = 0xFC ;
T2L = 0x65;
TR2 = 1;
counter++;
Thanks and regards,
Nikhilesh
