How to go from continuous-time OFDM to discrete-time?
David83
Advanced Member level 1
Hello all,
I am interested in understanding how do we obtain the discrete-time OFDM signal from its continuous-time counter part. In particular, the received OFDM signal over time-invariant channel of length L is given by:
\[y_n=\sum_{l=0}^{L-1}h_lx_{n-l}+w_n\]
where {h_l} are the channel gains, {x_n} are the N-point IFFT of transmitted symbols, and {w_n} are AWGN samples. Then we take the FFT of the above received samples as:
\[Y_k=\sum_{n=0}^{N-1}y_n\,e^{j\frac{2\pi}{N}nk}=H_kX_k+W_K\]
where H_k, X_k, and W_k are the frequency counterparts of the the channel, signal, and noise, respectively, and N is the number of subcarriers.
Now in the continuous-time, the transmitted signal is given by:
\[x(t)=\Re\left\{\sum_{k=0}^{N-1}X_ke^{j 2 pi f_kt}\right\},\,\,\,t\in[-T_g, T]\]
where T_g is the length of cyclic prefix in seconds, and T is the OFDM symbol length. The LTI channel impulse response is given by:
\[h(\tau;t)=\sum_{p=1}^{P}h_p\delta(\tau-\tau_p)\]
where h_p and tau_p are the channel gain and delay pf the pth path. The received baseband signal is given by:
\[y(t)=\sum_{k=0}^{N-1}X_k\sum_{p=1}^Ph_pe^{j2pi f_k \tau_p}e^{j2pi\frac{k}{T}t}+w(t)\]
I assume we do sampling next at t=nTs, but then what?
Thanks
