T
treez
Hello,
We are doing a 60W isolated offline flyback (120W peak).
We are using an ETD44 ferrite core with 1mm gap. The transformer winding company say that they cannot glue the ETD44 ferrite core halves together because it is not a robust method of adhesion. Is this true?
They tell us that they must instead use the core clips to hold the core halves together and then varnish the cores so that they stick together.
As such, do you agree that glue cannot be used to glue the core halves together?
The 1mm gap is in the centre leg (only) of the ETD44 core, and I believe that the core halves can be held together while the glue sets in the outer core arms by squirting “hot melt” glue into the air gap to hold the core pieces together whilst the outer ferrite arms are glued together. (obviously ‘hot melt’ glue cannot be used to glue all the surfaces of the core together because it goes soft at 85 degC.)
So do you agree that “hot melt” glue should be squirted into the core gap to hold the core halves together while the proper glue in the outer core “arms” drys off?
I presume you agree with me that the permeability of air and “hot melt” glue is similar enough to mean that the inductance of the coils will not be affected by having “Hot melt” glue in the gap instead of air?
ETD44 core datasheet:-
(Sorry to ask, though I felt many could benefit from this knowledge)
