How to get the duty cycle of a frequency with Hspic?
icpaopao
Junior Member level 3
I want to get the duty cycle with the 'measure'.
How can I do ?
Maybe this can do:
.meas tran T1 when v(out)='0.5*v(vdd)' cross=1
.meas tran T2 when v(out)='0.5*v(vdd)' cross=2
.meas tran T3 when v(out)='0.5*v(vdd)' cross=3
.meas tran Duty param='(T2-T1)/(T3-T1)'
Ryan
Thank you.
But I have 300 cycles. And I wanna get the average.
Then , how to repeat these'measure's quickly?
It seems we should repeat it 300 times for 300 cycles. I think. but I have another solution for your case: I often use a wave display tool - CosmosScope do this work. there are many function in CosmosScope that can measure different parameters.
Ryan
I use the cosmosScope,too.
But I need to repeat this process for many corners,so I want to find a convinient way.
And I am in the same trouble of caculating the jitter.
Could you have any advices?
Thank you.
I am also faced the trouble. so far, I haven't found a convenient way. For different corners, I have to do the same thing.
Ryan
LaTeX Commands Quick-Menu:
