How to get silabs Si1141 out of suspended mode
jokkeedk
Newbie level 1
Newbie level 1
Trying to read the PS1 values. But as im running the following code it keeps saying on "chip_stat" that its suspended.
main (void){
    init(); // Configuration initialization
    si1141_init(); // Si1141 sensor initialization
    __delay_ms(30); // Delay to ensure Si1141 is completely booted, must be atleast 25ms
    si1141_WriteToRegister(REG_IRQ_STATUS, 0xFF); // Clear interrupt source
    signed int status;
    while(1){
        WriteToI2C(0x5A<<1); // Slave address
        PutByteI2C(0x30); // chip_stat
        ReadFromI2C(0x5A<<1); // Slave address
        if((status = GetByteI2C(0x30)) == Sw_I2C_ERROR) // part_id
            return Sw_I2C_ERROR;
        Stop_I2C();
        status++;;
The code im using to read the PS1 values is the following. Im reading the value 16705. Which keeps being the same on all measurements.
The value should go up and down from 0 - 32767, as it measures more or less movement.
signed int si1141_ReadFromRegister(unsigned char reg){
    signed int data;
    if((data = GetByteI2C(Sw_I2C_LAST)) == Sw_I2C_ERROR)
    Stop_I2C();
    return data;
main (void){
    signed int PS1;
    while(1){
    PS1 = si1141_ReadFromRegister(REG_PS1_DATA0) + (256 * si1141_ReadFromRegister(REG_PS1_DATA1)); // Proximity CH1
I linked the files for the i2c communication.
https://www.dropbox.com/s/q41vw444gjvj0qa/swi2c.c?dl=0 https://www.dropbox.com/s/1mshyz88o15hz8c/swi2c.h?dl=0
