how to get precise time with pic - help needed
AriHell
Junior Member level 1
pic precise timing
I'm working on a small project and precise time is critical issue.
How can i get precise time?
Thank you.
Well, you can use a crystal or an external oscillator with a very small deviance.
How precise do you want to be? Even the internal oscillator on a PIC is stable and precise enough down to the <10nS range I believe.
I need it to be one sec precision.
Will i get it with 4Mhz oscillator?
Unless you use an R/C oscillator at that speed you will definitely be precise enough. That will give 1MIPS, so every 1,000,000 instructions will be one second.
If you are trying to time something within a second (really really slow) you may consider using an external 32.767Khz oscillator like a watch crystal on your TMR1 and have it interrupt every time it overflows. Or, use a RTC (look up the MAX1337) and have it assert one of its interrupt pins every second on an alarm.
Trying to count 1,000,000 cycles accurately with C or ASM is difficult because C introduces extra code you didn't intend to be there and ASM requires that you figure out how to do 24-bit or 32-bit math using 8-bit registers.
I'm will probably use 4 MHz quartz crystal resonator (HC-49S)
what is R/C oscillator ? how is it look like?
Stick with the crystal, far more accurate than a resonator or R/C osc.
If 1 second is what you're after use a crystal that divides evenly in binary such as.
4.9152MHz it's commonly available.
It's also possible (if you don't need speed) to use a 32768Hz watch crystal.
Crsytals give better accuracy. If you are using any crystal, try to use more accurate as possible with the values for better accuracy. Mean if you use 4 mhz, use a crystal with 4.000mhz marked on it. Good luck
it all depends on how "precise" you want your clock to be precise.
you can thermally insulate the devices / crystals, you can calibrate the internal r/c, etc.
without knowing more precisely your requirements, it is tough to help you.
one second over what period of time? 1 second over an hour / 24 hours is nothing. 1 second over a month is doable. 1 second over a year is pretty much out of the possibilities for most of us.
It suppose to work over a month.
Deviation of few minutes won't kill nobody however, I want the deviation to be as small as possible.
Re: precise time with pic
Quartz crystals provide u d best accuracy
Check out the ppm rating while choosing ur crystal
Lowest ppm offer better stability
I have a small question.
Suppose, i have a external 32.768KHz crystal connected.How can i maintain accurate timing if i want to run a normal clock?
I havn't worked much with this crystal so i don't have any idea behind using this crystal for RTC.
1 second over a month equates to less than 1ppm, and I don't think you will find any affordable crystals at that kind of precision.
1 minute over a month is about 20ppm and that's quite doable with regular crystals and no thermal compensation.
if you really need 1 second / month type precision, the least expensive solution is likely to get a high precision watch. Citizen I think used to produce a watch that they claim is good for less than 12 seconds a year.
that's going to cost you thousands of dollars.
I don't think you have any choice to use achieve high precision timing accuracy (let say 1ppm) without calibration and without temperature compensation if the device is to be exposed to large temperature variations.
I once saw a design using a silab DDS that uses a to220 transistor mounted to the oscillator as a heater to maintain temperature. Pretty cleaver if you ask me.
I put 4Mhz Quartz but the seconds go slower than what it suppose to go.
Is it because i use 30pf and not 22pf?
I guess it has something to do with how you implemented the concept rather than the concept itself.
Any ideaes how to fix the deviation?
