How to get power from USB cable?
vishmi
Newbie level 3
I can't get any voltage out my USB cable. I measured the voltage between the red and black wires of a USB cable while it was plugged into my laptop and the multimeter read 0 volts. When I connected these wires with a resistor it was still 0 volts. Does any one know why I'm not getting any voltage?
In case you want to know why I'm doing this, I plan on attaching a voltage divider to my USB cable so that it will match the required input voltage of my shaver, so I can charge it.
farhada
Advanced Member level 2
Nice, France
That is very strange, the power should be +5V, I have been using this for years.
Check out these links:
USB As A Power Source
Universal Serial Bus - Wikipedia, the free encyclopedia
Reactions: vishmi
    vishmi
RCinFLA
It has to be a USB mastering capable device. Many cellphones, MP3 player, external disk drives, and similar devices are not mastering capable (they can not initiate USB communications) and will not source 5 vdc.
Some computers save power by strobing 5v supply. You may have to tie a 1.5k from D- pin to Vbus to get source to maintain 5v supply.
Reactions: vishmi
    vishmi
vishmi
Newbie level 3
Thanks for your help. I have the voltage working now. I tried using another cable and it worked. Now I have a problem with getting enough current. I might be able to figure out the circuit if I knew the output impedance of the usb cable and input impedance of the shaver. i was getting strange results from my multimeter and so maybe i'm measuring impedance wrong. for the usb cable i got 0 ohms and for the shaver input it was sometimes 0 ohms and sometimes infinity. to get these results i just connected a multimeter lead with each of the two parts of the power wire (Vcc and ground). i tested the multimeter for known resistances and it tested normal. so basically, I need help figuring out the impedances.
Enlightenment
Full Member level 3
3rd Rock From Sun
You might be running into the default maximum current, which is set to a low-power device of 100mA. The device, your end of the cable, is suppose to send a USB request to become a high-power device of 500mA (which I don't know how to do). Some USB interfaces will supply a lot more current, but don't expect it from all USB interfaces. If you need a bunch of current, then plug into a USB battery charger, because many will source up to 1 Amp, and the new ones that support iPad will source up to 2.1 Amp.
john blue
Advanced Member level 3
Dont draw over 500mA if not you might have chances of getting your USB burnt
pranam77
Advanced Member level 5
INDIA
Yes...this point is to really considered to protect the port from excess current drain, and damage. Afterall you get a USB charger/ adaptor with 5 volts output for just 1$ usable for all these devices which would be preferably safe instead using the PC/ laptop for special applications.
Reactions: vishmi
    vishmi
vishmi
Newbie level 3
Thanks again everyone. I figured the device input impedance is about 50 ohms because it has 4.9 V and 96mA. However, the device is rated for 3.6V and 100mA. Do you think the voltage will cause any problems? I was going to add a resistor in series to reduce the voltage across the load but any more resistance would make the current too low.
vishmi
Newbie level 3
also, my device has a different impedance when it has a different power source connected to it. (63 Ohms) is it normal for devices to have impedance that changes?
