Axial Ratio in IE3D to Dr.Jian or any one else , please i need help in my design of microstrip antenna , i want to know how to get Axial Ratio vs. frequency display , i tried to get it from display menu in patternview and i found there are 37(theta) , each theta have phi (0 to 350) and i don't know how can i choose which of 37(theta) and which of phi (0 to 350) to plot on diagram (Axial Ratio vs. frequency display)
I tried to get Axial Ratio from 2D pattern display but i get Axial Ratio vs. Elevation angle
Yes. You just choose "Axiail Ratio vs. Frequency" for a specific angle of theta and phi. For different theta and phi, the axial ratio is different. Most designers only care about the axial ratio of the main beam. You should find the angels of (theta, phi) of the main beam and choose the combination. For example, a typical patch antenna's main beam is theta = 0 and phi = 0. Then, you just pick the angle combination for your "Axial Ratio vs. Frequency" display.
I've simulated and enclosed results here.I didnt find any difficulty.
U've simulated for only single frequency 3.92GHz in pattern file
If u want the result of axial ratio vs frequency for the entire band u've to simulate for the entire band.
In revised folder i've enclosed results of Axialratio vs frequency for both theta,phi = (0,0) & (0,90) in PDF format.
It is out of range for the display. It might be the automatic finding range does not apply. Please change its range to find it. If you can send me the .pat file (zipped), I can try to find out the true reason.
I tried many times to change (theta,phi) of microstrip antenna design in the frequency range (start frequency=3.8GHz , end frequency=4.2GHz, step frequency=0.05GHz) without anyresult and the radiation pattern of this design is 4GHz , i send to you the pat file of the design and geo file as the attached files and i hope you help me to know my mistake .
My suggestion to get axial ratio vs frequency was, Simulate that antenna from 3.8 to 4.2 GHz with 101 frquency points enabling both current distribution and radiation pattern in simulation setup.Then u can get axial ratio vs frequency plot.
Enclosed here is the axial ratio vs frequency plot (PDF)for your antenna and pattern file(*.pat)for the same.
Thanks for your reply , i want to know why the size of your pat file is 1.06MB and my pat file is 182 KB? , i think that is my mistake in this point ,when i apply your pat file (1.06MB) gives me result and when apply my pat file(182KB) doesn't give any result , how can i reach with the size of pat file to(1.06MB)?
I checked your file. You only simulated one frequency point. That is the reason you see no data in the "Axial Ratio vs. Frequency" plot. Please simulate more freuqency points for the plot, or you can check the 3D and 2D plots for axial ratio. Regards,
I want to thank Dr.jian and Mr.balaguru for their co-operation in my questions , the problem has been solved and i am pleased to join in EDAboard forum.
