How to generate sine waves using verilog?
keerthna
Member level 1
Member level 1
How to generate sine waves by using a verilog code? Can anyone please explain in detail? I heard about the look up table but have no clue on how to implement on FPGA? Can anyone post a sample code to help ?
Thanks in advance
By reading the documentation of the fpga vendor? Anyways, Xilinx & Altera both offer DDS cores. So if you use Xilinx you already had your answer in post #2. If you use Altera you now have your answer in post #4. And if you use another fpga vendor then post #5 is an excellent place to mention which fpga you are using. ;-)
Well, I just checked my webpack Vivado install and I could use the DDS Compiler without problems. And I recall a similar situation with ISE for webpack.
