How to generate sdf using max & min libs so sdf will consists of corresponding delays
viswanadh_babu
Member level 2
Hai All,
Iam generating SDF for only one corner using only one lib in common timing library option .
Can any one tell me how generate sdf using max & min libs so that sdf will consists of corresponding delays in one file itself.
Thanks in advance
Generation of sdf
Which tool are you using to generate the SDF?
Generation of sdf
Either Design Compiler or Prime Time can do it .....
Generation of sdf
use write_sdf command in DC to generate SDF file
Re: Generation of sdf
iam working on cadence soc encounter tool. So i wanted to generate the sdf using the same tool.
