How to generate ideal balun in layout?
rajeshree
Junior Member level 2
Hello everyone
i have generated layout of OTA design shown below. DRC is sucessfully run without ideal_balun
But i dont know how to connect ideal_balun in layout. please help me i got xfmr component error in LVS.
How can i solve it? thanks in advance
Hello rajeshree,
You need to remove the balun and the Voltage sources and add pins.
Thanks a lot sir
but i want to apply differential ac inputs to two inputs and input common mode voltage simultaneously than how is it possible? please suggest me how to do?
thanks in advance
After you add the pins you will need to make a symbol. [Create -> Cellview -> From Cellview]
Then you will run the simulation in another file, where you will add your circuits symbol, the necessary sources and the balun.
---------- Post added at 17:42 ---------- Previous post was at 17:38 ----------
Also check this file at pages 11 to 13
