How to generate hex file in assembly program?
mr_byte31
Full Member level 5
Full Member level 5
programming 89s52 ic
hi every body
i made an assembly program on uvision of kiel
but i dont know how to generate hex file
and put it on the ic
Re: programming 89s52
you must be use franklin software this program make .hex file automatically
for genertating hex see the project options in keil IDE AND CHECK generatre hex file box
if you want a programmer artmel has an application note about this check their site
hi .. to generate a hex file do the following
program -> options for target 1 -> output -> AND TICK ON "create hex file "-> and the click ok .
hope you got it .
LaTeX Commands Quick-Menu:
