How to generate HEX file for EPROM in Proteus?
epilot
I want to generate a HEX file for an EPROM in PROTUES.
Is there any way or any software to do ?
Thanks in advance
Re: HEX file for...?
Hi my frind
i face this problem befor and i think this is a very good question but what micro you use,i solve this problem with my own procedure...
tell me your micro i can help , if any one have a methode independent of the micro
please help
Medtronic said:
Hi my frind
please help
I am using 2732 Eprom..
Can you direct me to your procedure please?
2732 is your ROM, but not the CPU/MCU. Which type of microcontroller do you intend to use?
ATmega16
or PIC16F84
Both MCUs have an internal flash ROM. So there's no need and no bus to connect an external 2732 EPROM.
Generally a hex file for this internal flash is created by an assembler or compiler.
First you should elaborate some more details on your project ...
