generate ic from fpga
I need to generate clock from FPGA to drive another IC which is connected to the FPGA. Do I use a frequency divider or something to achieve ths where in I take the master clock from FPGA clock and generate the new clock? I am clueless about this. Help me with this. And moreover the IC that gets connected to the FPGA can be different as in the FPGA needs to drive different ICs so the clocks are different that have to be generated how can I make it dynamic with respect to the IC?
Thanks,
