Apr 20, 2006 #1 D deepa Full Member level 2 Joined Jul 3, 2005 Messages 127 Helped 3 Reputation 6 Reaction score 2 Trophy points 1,298 Activity points 2,226 from a single phase clock how to generate a two phase differential non-overlapping clock...
Apr 20, 2006 #2 K koppolu1981 Junior Member level 3 Joined Apr 20, 2006 Messages 29 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,283 Activity points 1,529 Re: two phase clock Hi, The question posed is not clear. Is this using HDL?
Apr 20, 2006 #3 I IanP Advanced Member level 7 Joined Oct 5, 2004 Messages 7,929 Helped 2,311 Reputation 4,624 Reaction score 531 Trophy points 1,393 Location West Coast Activity points 66,416 Re: two phase clock Use an inverter to generate the other phase .. Reagrds, IanP
Apr 20, 2006 #4 D deepa Full Member level 2 Joined Jul 3, 2005 Messages 127 Helped 3 Reputation 6 Reaction score 2 Trophy points 1,298 Activity points 2,226 Re: two phase clock yes,using HDL using an inverter ,will generate overlapping ,i want two non overlapping clocks..doesnt have to be 50 % duty cycle
Apr 20, 2006 #5 K koppolu1981 Junior Member level 3 Joined Apr 20, 2006 Messages 29 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,283 Activity points 1,529 Re: two phase clock ya, Inverter is the simplest if same freq is required. If same frequency is not required u can use counters with pos edge triggering and negative edge triggering.
Apr 20, 2006 #6 B balusu Newbie level 3 Joined Feb 3, 2006 Messages 4 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,307 Re: two phase clock if u want to generate non overlapping clocks in vhdl we can use process to call each clk.
Apr 22, 2006 #7 D dsocer Newbie level 6 Joined Apr 4, 2006 Messages 11 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,370 Re: two phase clock If u want to gengerate non overlapping clocks , the duty cycle must not be 50%.One clock can be trigerred by another clock
Apr 24, 2006 #8 J jcchan Member level 1 Joined Apr 28, 2005 Messages 33 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,569 Re: two phase clock to use SR latch and delay cell.
