buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 960
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,116
Hi
Is it possible to generate a short reset signal for internal logic without using a reset input pin to the FPGA?
I screwed up the PCB and the reset input is not available, I need to reset the internal logic by using an internally generated reset signal. For example when the FPGA configuration finishes, I need a counter to have a "0000000000000000" value. That counter will generate a 100ms reset for the rest of the logic. A 25MHz input clock is available, but the problem is how to make sure that the counter starts at 0x0000 value after config?
This is in VHDL and xilinx spartan-6 FPGA.
