I have a voltage signal and I want to use this voltage signal to generate a current output.
The simplest way is use V/R=I.
However, the R comes with serious variation in semiconductor process.
How can I use a known voltage signal to generate a "process independent" current output?
Re: How to generate a "process independent" curren
u can go through allen hallberg's book about current reference chapter , this will give you the initial idea about process independent current source.
wish u good luck.
