in a oscillator driven circuit, max current is usually going to occur when sum of load impedance's is at a minimum and maximum current will flow. This is USUALLY when the maximum number of driven outputs change, if they all have the same load, especially if capacitors are involved. The frequency these outputs change will also be a factor.
We'd need to see the circuit and values to give a clearer answer.
