oac
Newbie level 5
- Joined
- Jan 27, 2014
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 62
Hi all,
I'm building a receiver. The received signal is (low noise) amplified and has a frequency in the 2.45GHz band. This signal is mixed with a sample of the 2.45GHz generator. The resulting signal at the IF port has power around the frequencies 0Hz (DC) and 4.90GHz. The latter must be filtered away before IF amplification. The passband of the filter should be about 5kHz-1MHz.
I have two, possibly related problems.
1) I'm not sure how to make this filter. If I use a simple LC filter (theoretically lossless) it will reflect the 4.90GHz energy back to the mixer, and I'm afraid this will destroy the mixer linearity.
I'm aware of the existence of absorptive filters, but have no experience with their design. What do you recommend me to do?
2) How can I model the IF port of the mixer? The datasheet shows the IF output is matched to 50Ohms. I don't know how to interpret this at the low frequencies of the IF signal. Can i look upon the IF output port as a voltage source with internal resistance 50Ohm?
many thanks,
oac
many thanks,
oac
