dc component of a signal
how to extract the DC component of the sine wave signal V+V0coswt ??
that is : the input signal is V+V0coswt , when it passes through the system I designed, the output signal is V, or proportianal to V?
one may say a lpf will do this work , but if w is relatively low ,for example in the range of 100Hz ? such a lpf is not easy to design
moreover, this lpf is not a ideal one, so the AC component will remain ,although with small amplitude.
This may be a tough question , sincerely hope you could provide some ideas
many many thanks !!!!!!!
