arikp
- Joined
- Dec 25, 2008
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,325
Hi ,
I am trying to find a way to simply extend the input voltage range of a TPS563200 device or alike that will enable input from 4.5V-21V instead of 4.5V-17V ( the original range of the device).
First coms in mind is a FET feeding the VDD of the device by controlling its gate using zener at fixed voltage. Drain is at Vin and Source feeds the device VDD. The problem is that I lose the VGSth margin so I can only work minimum from 4.5V + VGSth Which is above the original minimum I need.
I am looking for a trick that can get me the original minumum voltage back and still keep the FET.
I am looking for a very simple solution.
Thanks for the helpers ,
Arik.p.
Arik.p.
